Jim Reire
  1. Personally, I change the oil and filter in my 2020 Kodiaq 2.0 ltr tdi 150 hp every 10'000 klms, using Castrol 05w 30 long lasting oil and MANN filters. I check it routinely, and generally find that at the 5-6'000 klm, it needs a 250-300 Ml of oil. Does this ring any bells with anyone?
  2. I've just heard the use of the word KISS in relation to VAG automatic transmission.( Mechanitronic ?) any one familiar with it? Possibly to do with linking the transmission to the engine?
  3. 10-12 ltrs between services??? Those are oil changes in themselves....that's not normal. My new to me Kodiak 1 (2020) has needed about 700ml, straight after collecting it from the dealers in May, and now at 3'500 Klms it needs about 500 Mls, but as I'm planning on changing the oil and filter this week, no need to top it up. But, I'll be keeping a good eye on it. Anyone any ideas or suggestions on what else I need to keep an eye on? All contributions greatly received.....😀 Thanks, Jim
  4. In an ordinary manual transmission that starts to make a noise during a gear change up or down, I'd suspect the thrust releast bearing being the culprit, especially as the clutch is not slipping and working fine otherwise.
  5. If you apply the handbrake, select 1st gear, and slowly release the clutch, will the engine rev up or cut out?
  6. Have you had the OBD scanned to see if its showing any fault codes???
  7. Yes, 500KG or thereabouts would be my normal towing...a Honda 2417 ride on Mower, rarely anything heavier, but its essential that I be able to move it around. Thanks and Best Regards, Jim
  8. Finally, I found the VIN/ Weights plate and yes, it was on the bottom of the "B" pillar, low down, and on an inward curve to the rocker / sill panel, difficult to see at nigh time, and even in good daylight also because half of it is in the shadow of the rear door. Anyway, here it is, and apologies for the delay. Thanks for all your help and Best Regards, Jim. Kodiak Piller Plate Weight 20260621_151145.heic
  9. Hi again Evolution, sorry for the delay in replying to you, but finally got the Kodiaq back from my daughter this afternoon ( if you have daughters yourself, and they borrow something just for a day or two, you will understand) Anyway, there's no such towing weight's limit plate anywhere on the car that I can see! And another member is saying the same thing. What I have discovered is : 2'000 Kg Braked Towing 2.0 tdi 4X4, 2'200 Kg Braked Towing 750 Kg unbraked towing. But I'm not finished looking yet. And as soon as I have more info, I'll get back to you. Best Regards, Jim.
  10. This is my first Skoda Kodiaq, and despite many years of driving all manner of Skoda's and while I can fit towbars no problem, I have no experience in fitting them to the Kodiaq 4x4's. I suggest you contact your nearest Skoda dealership for definite info on the subject. Personally, I cannot see why not....but with modern vehicles, you cannot tell!!! Best Regards, and let us know how you get on, OK? Thanks Best Regards, Jim
  11. While not 100% sure, I think that in the 7 seat Kodiaqs, the towbar is standard,,,when not in use, its out of sight, tucked up behind the rear bumper. A simple way to check is to lift up the tailgate, and on the drivers side rear panel, there's a small pull catch, with a hook emblem on it, and this is the release for lowering the towbar. No pull catch, no towbar. Best Regards,Jim.
  12. Yes, that I will do for sure!! I've enough experience dealing with insurance assessors in the past to know that they will not leave any stone upturned in their efforts to reduce or better still, deny a claim!! Best Regards, Jim
  13. Update on my Kodiaq listed as a 4x4, but in reality is only a FWD... So finally I got the Registration Document ( V 5 in the UK? ) and its listed as a JEEP/ESTATE.. no mention of 4x4 anywhere, and true 1x0. So in due course, I contacted the insurance, and informed them that the car was not an 4x4, but they insisted that when they inputted the reg nr. that what came up was it was a 4x4, and it was on that basis that they were insuring it on. So I said OK, fine by me, as long as if I ever have a claim, you wont try to wriggle out of it based on your assessment of it being wrong. So here we are....Car is a delight to drive, handles very well on the road, plenty of power (for my needs at any rate) Even the 6/7 th. seat's are very comfortable, surprisingly so. They are not something that I would pick by choice, but in the Kodiaq, they work. Thanks again for the help, Regards, Jim.
  14. Judging by the pic, that will need repairing by someone with experience..the sill panel is actually split away from the floor pan.,,so a lift, and a MIG welder will be needed. But at least you have caught it in time.....and while its on the lift, give it a thorough inspection for any other lurking rust problems. Good Luck, and Best Regards, Jim.
  15. What does this update file do? Thanks, Jim,
