Everything posted by Monkhai
Fault codes after changing battery
Adjusting the sensor required specialised equipment. Have you cleared the codes and seen if they come back as low/high voltages can cause odd behaviour with sensors in my experience.
taking pcp for benefits then cancelling?
But they should be in the contract…
Go to dealer, ask for a copy so you can consider your options. Finance is regulated, so all finance companies have to give you contract terms.
Recommend me a dashcam/ Are cheaper dashcams worth it?
Vigo a229 plus looked to be a good compromise on price vs performance and had a starvis 2 when I last took a look. They (and others) did a 2k super compact with no screen too.
Military paint suggestions
If it’s rust underneath, why not clean it up good, then paint the sills and immediate area with black undercoat. Spray the under area with waxoyl or Bilthamber syntax/dynax UC? Yes that only deals with the undersides/wheel arches and hidden areas, but roller finishing a car would look naff. Might as well just hammerite it at that point 😂
Acoustic Glass
You could read that as acoustic in the front and sunset in the rear…
Changing AGM battery from one with 650 CCA to 750 CCA do I need to get car recoded
If you are not sure that the original battery was correctly coded from EFB to AGM, then I would get it coded. The voltages are a bit different and the coding on many cars resets an “aging profile” for how the battery is charged.
- MK4 Octavia vrs rear brakes.
Anyone running on CrossClimate 2 225/50R18 MICHELIN CROSSCLIMATE 2 SUV ?
Whatever you do, do not run summers on the rear and anything more winter/all season targeted on the front. It would likely be easy to lose the rear end in snow/ice.
Dash and radio clock are different times
Moved to yeti forum
Depends where you are no? Wilds of Scotland or half way up a rural pennies road sure, winters win be they Nokian, Alpine 5/6 or any other decent brand. Cornwall probably less so. You need to buy new wheels, pressure sensors, tyres and store/swap them. Yes I travel, but as snow is uncommon where we now are, getting home in snow matters rather than hacking it around. If I had unlimited space and budget I would get summer/winter for piece of mind. If the weather became reliably colder too. As it stands the wife drove a long drive home on cc+ during the beast from the east after digging her car out. If they were that bad I’ve had hear about it. I would far rather encounter a car on hood all seasons than summer tyres even if I’m on winters though. Less likely to plough into me.
I’ve used both extensively over a number of years/cars. Good All Seasons are plenty good enough to get you home or to the shops. Deep snow up a hill, they’re probably acceptable when it’s fresh, but yes it’d be better on winters. Slush that’s refrozen would be much better on winters. All seasons do have an advantage on our typical wet roads or dry cool vs winters IMHO. Gets very cold or icy and winters win. Both are hugely better than summers in winter though. Essentially how severe is the weather you’re expecting, how often and are you just needing to get home or to travel? Only you can tell, which trade off (storage & changing vs worse performance in more serious conditions) works for you.
Not that size but a 19” on a different vehicle. They’re very good. Had full winters/summers and cc2 on an Octavia and not as good in deep stuff/ice but much much much better than summers. Both the wife and myself run them now as we don’t currently get the snow load to justify two sets of wheels /sensors /storage.
Superb MK2 Alternator Removal
Although it m not sure the Passat info is correct myself
Maxi-dots
Please don’t post duplicate threads:
DIY servicing on MkII Superb?
The Octavia or that age had a top mounted oil filter, so changes were very easy if you were willing to use a pela pump or similar.
Ryobi multi material saw
I have a mains powered mini plunge saw and have to say it’s fantastic for cutting sheet materials down to size.
Octavia MK2 2011 Estate brake discs
Check the manual, if it’s the DPF light there are instructions and you need to take the car out and follow those instructions.
Not a sight I expected to see....
Usually with the early i5 and sister cars, it was a dead 12v, so you couldn’t turn the HV or zombie mode. The latter being where the software got confused and the start button wouldn’t work until keys went out of range then you unlocked again. Zombie mode definitely got fixed and fewer and fewer people see 12v problems after software updates.
Real world recharge rates - what is people's experience?
Completely different to the iPace, but I see 200kW+ regularly on the right chargers (15-20 minute charge window). I would say unless the chargers are playing up int in the range of 120 (140 most of the time) to 240kW (220 most of the time). I deliberately chose a vehicle with an 800v battery though, as I have different priorities.
The next generation MINI Cooper Electric 2024 & MINI Aceman 2024/25 pics & Videos.
Still a hard no here, particularly at the price. Feel like the clothing brands that used to buy a 50p polo top, add their logo and decide it was £80 now 😂
New entry level BEV the Epiq to be launched in 2025
I can’t live with 45 minute charge windows whilst out, as I can charge multiple times in a day. 800v makes a bathroom break a substantial charge on a decent charger. They have pushed out marketing about an Octavia estate mind.
Next time it happens try the stops if you can find somewhere safe. Worth checking the wishbone bushes , faces of the hub etc too (as mentioned by another poster) Never had problems with warping, but hot pads will leave deposits on discs (for example hard stop or lots of braking) then standing on the brakes rather than using the handbrake.
Skoda Octavia 2015 (Coolant Issue)
I know there were some radiators on mk2 and possibly early mk3 where there was a crack/poor manufacturing that would open up when hot and dump all the water. I am not saying it is this, but worth checking the leak isn’t coming from the edges of the radiator if you can’t work out what else is going on. Also I’ve moved this to the mi3 area.
I’d be looking at the pads and it’s very rare for discs to “warp” and more likely for pads to leave deposits. The advice I received back when I had a mk2 was that if it was safe to do so, to try a few hard stops from 70 to 20 on an empty dual carriageway. If there are pad deposits, this should reduce them. That said, what symptoms are you seeing that makes you think your discs are “warped”
