Everything posted by faboka vrs
Left Foot Brake override possible?
Yup and helps smooth out weight transfer which was the reason I wanted to disable it. I’m just not good at it haha
Tyre sizing
Or ditch the Jabba and fit a 25mm H&R one which is even stiffer 😎 Never had an issue with the Jabba or H&R when fitted with decent tyres.
Recent pics of your fabia for no reason, just stick em up!
Thanks. In the past year it’s been hit twice on the rear passenger side so got to sort that out at some point. But for the age the paint works not bad.
- Recent pics of your fabia for no reason, just stick em up!
- Left Foot Brake override possible?
I disabled the power cut in the ecu mapping. Just never got round to learning left foot braking properly.- vRS Restoration/Upgrades
I use mine more as a toy nowadays doing autosolos’s. Remap? Personal thing but I’ve now put mine back to stock. Polly bush. Not for me. Squeaks do my head in when the grease wears out. I’d use stock bushes with seat Ibiza solid rubber console bushes. rear anti roll bar. Yes. Either H&R or Jabbasport. I personally think the whiteline isn’t stiff enough. Dampers. Stock will be well past it now, wasn’t great when new. I really like my bilstein B8’s. Maybe koni sport would be another option. front camber. I use silverproject camber top mounts set to max camber which is almost 3 degrees. I put this in the same must have bucket as the rear anti roll bar. Springs. Keep stock. With the above setup on eibach springs I was running out of suspension travel and bouncing off the bump stops. brakes. I’m now back on stock from running 312’s. They have plenty of power.- Figuring out which gearbox my car has.
The long ratio box will do about 110mph in 4th at 4K rpm. The shorter box does around 90 if I remember right.- Fabia vrs clutch kit
I’d say don’t touch the DMF unless it’s showing signs of going. You can get the Sachs 3 price kit of carpartsforless for around £180 at the moment with the current sale offer.- Fabia vrs is it worth fitting aused garrett pd130 to replace my kkk before it dies or just go pd150 or hybrid
I wouldn’t touch xmans hybrids but that’s just me. stock gt1749vb (pd150) is good for 190bhp and will need a better intercooler setup. stock turbo is good enough for me but I’m getting older now- Decat exhaust
Pointless “performance” mod. Only thing that will make a noticeable difference to performance is a remap.- Fabia vRS - Bilstein B12 Alternative ?
The b12 kit is good. Have you thought about looking for some second hand ones and then get bilstein uk rebuild them? - Recent pics of your fabia for no reason, just stick em up!
