2 questions
as above
1.does a 52 plate vrs supposed to have auto closing of all windows when you lock car with remote?
2.is the interior lights supposed to come on when you turn the ignition off?
Hi,
1. Auto-closing of windows was not an option. You can buy aftermarket devices to do this if you want (do a search)
2. Yes when you take the key out of the ignition, lights should come on, stay on for about 30 seconds then fade out.
as above
1. No, but search KVW100. I have it on mine, for full window open / closure from the keyfob.
2. Mine does:thumbup:
Auto closing of windows on mine can only be done with the key. Hold the key in the lock position and all the windows and sun roof will close. On unlocking the door with the key, hold the key in the unlock position and all the windows can be opened to dump the hot from the car.
Check the interior light switch is in the right postion and not turned off :)
Here you go, my car with KVW100:
