Octavia Cruise Control Problems
Hi I am now on my 4th Octavia but this is the first one that has had cruise control Sometimes it works okay until I use the indicator control which is the same arm that the cruise control is on Once I have made a right hand indication the cruise control fails to work again until I stop and switch off Then when I start a new journey okay again until I signal right I believe somewhere I have read that this problem may also have occured on VW and Seat Any information would be helpful
Welcome
Assuming you have an Octavia II then you have a very common problem however this is the welcome section and not the questions section.
Please either try the search (you will find the answer) or post the question in the appropriate section.
Welcome to briskoda
Davy
welcome
Hello :)
Welcome.
Welcome to Briskoda..:thumbup:
