Big screen advice
Hello,
I'm looking for a bit of advice for buying a large LCD screen.
Essential specs:
52"ish in size
1080p resolution
Ability to connect to a PC at panel's native resolution
RS-232 control system with public protocol.
It's primarily going to be used as a digital noticeboard, and I was looking at the Sharp LC52X20E before I saw that it would only connect to a PC in the following resolutions:
VGA 640 x 480
SVGA 800 x 600
XGA 1024 x 768
WXGA 1360 x 768
SXGA 1280 x 1024
SXGA+ 1400 x 1050
which will presumably lead to a blurred picture when hooked up to a PC?
Thanks in advance,
Is that when using the VGA input?
I've seen that on a lot of panels , but if you feed the HDMI input from a PC with DVI output then you'll be able to run at the full 1080p resolution.
The Sony KDL-40W2000s we use for just that sort of purpose have the same limitation on the VGA
We've got one of them at home - we've never had any blurring happen using the VGA input, although we can't get it to display without a black box round the outside of the picture when watching iPlayer or WHY...
OK, thanks Alex (again!)
If you decide to go for a Bravia, let me know :)
