oil filter
what one do i want? 1.3 felly
You want a part number?
Just ring a motor factors up or go into halfords and they'll know what sort you need!
Alternativly go to a local motor parts shop.
Unipart or Partco have loads. I got my brake pipe from Partco.
got one now, £3.99 at halfrauds cheers chaps and chapettes
  • 4 months later...
(re-opens old thread)
I'm just about to fit a Champion C104 to my Felicia 1.3MPi (135) - I saw that it was an equivalent to Halfords HOF200 for lots of vehicles but it is not specifically recommended for Felicia - can I use a Champion C104 on my Felicia 1.3L? Have looked and looked on the web for Champion info and can't find an answer.
Where the oil filter threads onto the block seems to be solid metal - I can't see how it works to be honest!
Tim
Thanks Jorily - I fitted the Champion C104 anyway and no nasty noises and the filter warmed up, so I guess the oil is getting through it. :)
What was confusing me was that there is only a single hole in the block for the oil flow; on other vehicles I have changed oil filters on there seems to be a large void around the central thread and I was wondering how the single hole was going to line up with the filter hole(s). I thought about it and realised that the shape of the filter facing means that all of the holes will still be used but what concerned me a little was that the C104 has 4 largish oilways around the central mounting whereas (e.g.) HOF200 has many smaller ones. Maybe the flow is reduced then - Hey, what do I know about it anyway?
I'll get a genuine one for the next change - this one seems OK: engine quiet.
Tim
