Clearance problems !
Well I have put the wheels on I wanted 17inch Fox
Lowered the front by 35mm , and put Golf GTI springs on the rear , which gave me about 30mm on my Felicia Fun
Now I personally like it , but the major problem I have is clearance on the front ! As you can see from the photos , there is hardly nothing and any bump causes the wheel to hit the wheel arch.
Any suggestions to someone on a BUDGET ( the wife wants the conservatory finished !)
I can only think of a few
1. Change the wheels ...........but I like these ones
2. Coilovers.............too expensive
3. change the front springs..........expense again
4. Cut inner lip of wheelarch ............well it will help in a straight line lol
5. Fit "flintstone" front dampers so there is no movement ..........I can see this being the only possibilty ?
Don't suggest a "lummox" air suspension mod .....I cant afford it ( by the way how much does that cost Hmmm)
Stuart
22612.attach
22613.attach
22614.attach
i had the same problem on my felicia i got some bumpstops and fitted them to the dampers so the wheel wouldnt go past the arch as it would hit the bump stop if that makes sense they were £16 for 3 from haolfords only down side is theres hardly any suspension on the front :( but least she sticks well :p
Now thats the type of fix I am talking about , nice and cheap , excellent idea!!
Thanks for the suggestion , I will definitely look into it and see what suspension travel I have actually got to play with
Decided in the end , due to the lovely condition of the roads around me !!! That lowering my Fun this low is just not going to work !
Put my original springs back on for now , and the Felicia lowering springs have been put on Fleabay !!
put a big spacer in between the top of the damper and the top mount so it sits higher
