Maxidot buttons doesn't work
After i had my battery disconnected yesterday can't i switch between MFD/AUDIO/NAVIGATION/PHONE/SETUP in the maxidot
No matter how long i hold the button it just change between the functions on the MFA.
If i set a new destination on the navigation the maxidot shows arrows like normal and the maxidot shows incomming calls.
Is there a setting or something i can check with my vag-com ?
Henrik
Henrik
When I used my VagCom last time, I went through all settings I've had access, just to see what was there. I remember that there were (somewhere) check boxes for Bluetooth, for radio, for Sound System etc, etc. Those chack boxes said "Bluetooth Installed" for example. Try to find them and see if they got unchecked when battery was diconnected. Worth to try and do it slowly, setting by setting and read carefuly, not to miss something.
Might be worth checking the coding for the steering controller.
ill go with stu, it can't be hard to sort out. have you done a quick scan to see what fault codes you have?
I have just scanned with the vag-com and found this error
I don't know if this has anything to do with it.
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Coding: 3D3F4FC8072302
Shop #: WSC 30058
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 222
Mileage: 16754 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:03
Henrik
Some of the things that it says are fitted to your car are as follows -
Climate Control
Park Assist
Auxiliary Heating
Towbar/Trailer
Radio
Telephone
Do you have all of these and if so is there anything you have that isn't listed?
yes i have all that installed.
I'm not sure that it is park assist. Isn't there two types park assist and park sensors.
The navigation is a Skoda Columbus and my VAG-COM is a 704.1 can't see it correctly.
Henrik
( i'm going on vacation tomorrow, so im not back until the 23th)
Can you post up a full autoscan for us Henrik
Saturday,12,July,2008,10:19:53:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 69 72 76 77
7D
VIN: TMBGS61Z462176006 Mileage: 16930km/10519miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 016 K HW: 028 101 223 7
Component: R4 1,9L EDC G000SG 7002
Coding: 0000071
Shop #: WSC 73430
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Coding: 0021121
Shop #: WSC 73430
Address 08: Auto HVAC Labels: 1K0-907-044.LBL
Part No: 1Z0 907 044 J
Component: ClimatronicPQ35 084 0305
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Coding: 8B888F030004140000110D000000000000087F075C
Shop #: WSC 73430
Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.LBL
Part No SW: 1K0 909 605 M HW: 1K0 909 605 M
Component: Q2 AIRBAG VW8 024 0700
Coding: 0020786
Shop #: WSC 73430
Address 16: Steering wheel Labels: 1K0-953-549.LBL
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
Shop #: WSC 73430
Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D
Component: KOMBIINSTRUMENT VD1 1612
Coding: 0003101
Shop #: WSC 30058
Shop #: WSC 30058
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 222
Mileage: 16754 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:03
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Component: IMMO VD1 1612
Address 37: Navigation Labels: None
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.LBL
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2345
Coding: 0000246
Shop #: WSC 73430
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 18D002407F2D850D484FC61004CC
Shop #: WSC 00446
Part No: 1Z0 951 171 A
Component: NeigungsSensor 008 5003
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: Innenraumueberw.008 5003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.LBL
Part No: 1T0 959 702 B
Coding: 0000246
Shop #: WSC 73430
Address 56: Radio Labels: None
No Faults Found
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN2.LBL
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2435
Coding: 0000144
Shop #: WSC 73430
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.LBL
Part No: 1K0 959 704 E
Coding: 0000144
Shop #: WSC 73430
Address 76: Park Assist Labels: 1Z0-919-283.LBL
Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C
Component: Parkhilfe 8-Kan H04 0020
Coding: 0010011
Shop #: WSC 73430
Address 77: Telephone Labels: None
Part No SW: 1Z0 035 729 B HW: 1Z0 035 729 B
Component: FSE_2P7x H31 0050
Coding: 0000422
Shop #: WSC 00000
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 28
Reset counter: 188
Mileage: 16754 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:07
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 228
Mileage: 16754 km
Time Indication: 0
Date: 2000.00.00
Time: 15:21:50
Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
End --------------------------------------------------------------------------------------------------
Shop #: WSC 30058
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 222
Mileage: 16754 km
Time Indication: 0
Date: 2000.00.00
Time: 14:38:03
that is what i think it is!!
IMHO this fault -
Shop #: WSC 30058
1 Fault Found:
Is caused by this -
Coding: 0000422
Shop #: WSC 00000
2 Faults Found:
You've not wired your phone correctly and have a break in the CAN communications.
Sort that out first and see where we go from there. You won't be able to switch to the phone as the gateway can't see it
OK, ill have a look at it.
But the phone works OK. Shows calls and phonebook on the MaxiDot and the Columbus.
But ill lokk at the wires or disable the phone with the vag-com
Henrik
