Changing Bulbs...........
Not without significant injury/time/potential dent in wallet* it seems :mad:
:soapbox: Ok, so I've been known to change headlight/sidelight/indicator bulbs* more frequently than Tom_vRS changes cars :D which is not a difficult task in the fabia, but Feck me is it a P.I.T.A in the Roomster
I had a go this evening and only suceeded in changing the dipped beam H7's. The sidelight bulbs and indicator bulbs are completely inacessaible (sp) without removing the headlight assembly (no, I don't know how it's done, but belive me i tried)
Any pearls of wisdom (failing that workshop manuals :D)
*delete as appropriate
I changed the H7's (BTW there is only on H7 for dipped and main) but haven't had any need to go anywhere near the others.
I haven't needed to go near any of them, it's a case of wanting to :rofl:
:orb_hypno Must change orange indicator bulbs, Must change orange indicator bulbs, Must change orange indicator bulbs, Must change orange indicator bulbs, :orb_hypno
Once a modder, always a modder
Seriously though, I wouldn't fancy changing any of them at the side of the road :thumbdwn:
Dear lord you dug that one up!
One of the first things I did however was swap the standard H7's for Phillips Extreme which are a bit good.
I did the H7's for nightbreakers and got the indicators changed to philips silver thingies. The indicator on the drivers side is a PITA because of the cannister, I got it with a bit of contorsionism though and I have got hands like a seals flippers.
I have given up on the side lights though ...... I have lost enough skin on it already LOL
All you need is long and thin fingers... :D
Any chance of you flying out and popping my LED sides in then please mate :)
any chance of you flying out and popping my led sides in then please mate :)
No hope for Mr. Chubbyhands here then :rolleyes:
Edward Bratwurst fingers strikes again :D
:rofl::rofl::rofl::rofl:
So far, I've only changed the H7 headlights in my Roomster. Not the easiest of tasks, but luckily my hands are quite small. Needed less than five minutes.:cool:
Well, it seems that is not an easy task.
I am about to change my bulbs to PIAA's Xtreme White Plus (headlights and fog lights) and it would be interesting if someone can post pictures of the process. I certainly do not have thin fingers :/
Jeff
if you have a look in the fabia section you will find my post on something similar. found it impossible to change my side lights. took it into skoda for them to do it, they told me that they had to remove the inner wheel arch to get to it. told me it was 44 quid too, fat chance!! only paid 7 in the end
If you are really stuck Norwich Halfords are very good at changing bulbs for not too much dosh, they did my megane headlight bulbs , now that is nightmare, insert hand in small hole in wheel arch and pray, or as handbooks says this job should be done by dealer this was shown on tv as charges were between £35 £300 on one model, i now have a skoda
Just changed another H7. For some stupid reason, I can get only one part of the lamp to get stuck behind the clamp-thingy, where it should be done with two. Any ideas?:o
Just done my Roomster's front indicators, and didn't find them too difficult. Agree that the driver's side is a bit of a pig due to access, but it still didn't take long.
One thing that makes it worse is the only-just-long-enough cabling for these bulbs.
Any tighter and Eric Clapton could probably get a tune out of 'em...
And yep. Goofed so it seems. Took the bulb out again, turned in around 180 deg and voilá, it fitted!:rofl:
