Wall mounting USB hub...
I am after a source of port powered (ie no power supply) USB hubs that have a method of mounting them on the wall relatively securely (ie better and more professional than velcro/blu tack etc).
Something like a little round keyhole like recess in the back to interface with a screw head that looks something like this (ASCII art alert):
[font=Courier New]  __[/font]
[font=Courier New] |  |[/font]
[font=Courier New]/    \[/font]
[font=Courier New]|    | [/font]
[font=Courier New]\____/[/font]
would be great. Also if it had an inbuilt lead to the host PC of around 1 metre in length that would be good too.
Anyone seen anything like this?
Perhaps have a look on the back of your hub if you have one, which of course they never show on websites that sell them, and see if it could be mounted on a wall, if so put the make/model in the thread :thumbup:
Ta.
Edited by maffwilson
Belkin's normally have them.
I have this one and just turned it over to have a butchers. There are no screw holes to be used, but maybe you could use the hole in the middle of the device somehow.
I used to have this Belkin one and it certainly had the detail you describe, that would allow you to hang it from two screws on a wall, if required.
Only thing with this model was it was just USB 1.0 speed. Depends what use you have in mind for it I suppose? Also, while supplied with a power adaptor, lower powered devices were able to be run without it. So as long as you're not wanting to put a USB scanner or external HDD on it you'll be OK.
Steve
Doh
Edited by skomaz
just realised I'm talking bo**ox
The power supply is required by the spec if you want to run over a certain number of devices or a certain pull.
IIRC each port on the PC can only give 300mA, but I could be wrong, so the hub has to then share that between all the ports it has :(
