Confused by fuse
Hi
My cigarette lighter/power sockets aren't working. I went to check the fuse but couldn't make sense of the table in the owner's manual - I thought the table was just shown in reverse but in that case some of the fuses are missing, including the one for the power sockets. I used the power sockets last year so they have worked in the past! Does anyone know which fuse it is?:confused:
Thanks!
YL
Edited by yorkshirelass
Forgot to say it's a 2007 Roomster 3 1.9TDi
The table is probalby based on a LHD car which will be in reverse to yours. It is also quite common for it to list fuses which are not applicable to your car.
If you turn it the right way up will make sense.
Have you checked the one in the boot works?
Can't remember off the top of my head where is should be but What I normally do in times like (When I don't know which fuse of if it is the fuse) this is pull each fuse in sequence to check for a blown one. If you have no fuses blown and they are all out you may want to get the codes read (I think a fault like that should show up).
Let us know how you get on.
Edited by Decron
