Clutch Advice
Please keep this one on topic people :)
Right,
my clutch has packed in (just driveable and no more)
The car has a Revo Map, not too agressive i dont think..but has just lasted 114k on the original clutch.
Not planning on chasing more power, so i dont see the point in spending pennies on an uprated item/smf etc...
I currently have a spare DMF sitting here.
What else do i need ?
Can i just buy the oem sachs item from GSF at £89 + vat ?
Or do i also need a release bearing (cant find anything listed for the ASZ though)
Thanks people. :)
When i changed mines in a similar situation to yours i never changed the release bearing and its been fine since :)
Its fun driving around with hardly any clutch isnt it?
Great fun...especially when it comes to hills :D
Is there anyway to tell if the release bearing is in need of replacement ?
You mean the thrust bearing?
It will rattle and make noise in neutral and this should dissapear when you depress the clutch.
No idea bud, i never got one with my kit so didnt assume i'd need one. Tbh for the length of job you might as well whack a new one on while your there especially with higher mileage
Oops.my bad.
Something in my head said it was called that. :)
Well it certainly doesnt make a noise at the moment. :)
Oops.my bad.
At 114k I would get it done if your getting the clutch done regardless as if it goes then it's gotta come all apart again.
Righto...cant see them being too expensive. ;)
So that, and this www.vwspares.co.uk
Thats very reasonable.
