Diverter valve
id have said the forge remote DV would be easier to install and probably cheaper looking at that lot
Having had a Forge Diverter myself I now run with a similar setup to that that I made up myself.
I prefer it as it retains the OEM operation of the Diverter.
Ok, I assume that Forge Diverter is pretty much the same like OEM Diverter, just better materials used, right? Then what is the benefit of replacing it – smoother operation or …. ?
The Forge diverter is a mechanical valve which uses vacuum as to operate it as opposed to the electronic OEM DV.
