Samsung Tocca Bluetooth compatibility
Hey guys,
Sorry, I can't seem to find the compatibility list that I'm sure is on here somewhere.
Does anyone know whether the Samsung Tocca is compatible with the Bluetooth kit in the Octavia? I was thinking of an iPhone, but I don't think that works with the Kit, much as I'd like one, so the Samsung seems a reasonable compromise.
Any help would be greatly appreciated.
Martin
I have the Tocco.
It works with the OEM Bluetooth just fine.
The only thing different from the V3 set up I had previously is; on two occassions I have had a buzzing sound (only lasts about a second) before the phone connects to a dialled number for the first time.
Not worth investigateing and has not altered the performance of the unit, works great.
Cheers guys, Geeod luck for Tuesday Guiness,
Martin
I've added Samsung Tocco to the list, is it fully compatible with contacts etc?
Works fine Stu.
Full Contact list, Phonebook, Last calls, Received calls, etc.:thumbup:
Hi all got the samsung tocco connected to the car but all my contacts are not showing,they are all on the sim card but ive connected about five times and it's still not updating,it shows numbers and contacts,has anyone else had this problem?
Hi Golfman.
Ive had the Tocco for about 5 Months now. Works fine.
All my contacts, last call, dialled calls, etc show OK.
My contacts are on the phone, not the sim card. Try moving them to the phone from the sim, see if that sorts you out.
Hi Golfman.
Hi muppit thanks for the info tried it and it's not quite there but more of my contacts are coming up now,should be fine thanks for that.:thumbup:
still having problems it's just not showing all my contacts,sometimes it's only showing some letters of the contact?anyone got any ideas!!!!HELP:thumbdwn:
Hi all i took my tocco back to the shop and got a new one but it's just the same,still only showing some of my contacts yet when you look in missed or last calls the ones that are missing in the phonebook are there,is there any way to reset the bluetooth kit and try to pair them again?i can't understand why my nokia 6500 classic slide connects with no faults and even if you add a new contact it updates straight away!!!anyone have any ideas?
thanks golfman.:weeping:
