Octavia II Door Screw
Hi,
I was wondering if anyone could tell the the type of driver I need to tighten the M8/20 screw on the door. It's not the main hinge but the wee black bracket in between. I thought it was a torx 40 but it isnt and only managed to strip the head of the screw.
I have a new screw now from my dealer (ordered via phone and posted) but the spares department could not tell me what head was on it. The part number is N 908 961 01.
If anyone could help or point me in the right direction where I can get a tool to tighten this correctly I would be most happy.
Thanks,
John
Does it look like a star, if so try a spline set.
Should this not be merged with this thread?
:duck: Sorry, couldn't resist.
Yes, it looks like a star. Never heard of a spline set.
Thanks.
John
They come in various guises but here is an example
Thanks guys,
Thats what I'm after.
John
I always assumed these were torx, if not so whats the difference between spline and torx?
Torx are 6 point
I think the spline set is 12 point
Isn't the German type a triple square (which is slightly different from spline drive)?
Edited by brad1.8T
Torx are 6 point
So you may probably be able to get a torx bit into a spline screw but not vice versa (might explain why I was able to get at some of the trim screws on mine :))
Glad to see I am not the only one who has to tighten this screw a couple of times a year. Only on the drivers side door though (strange ?!?!?)
Isn't the drivers door the one opened the most?
Tried using studlock/threadlock or similar?
Yeah, but it will butcher it fairly quickly.
Torx seem to have a slight angle on them so even if they fit in the slot perfectly, they won't be 100% engaged.
