OpenSource DB
I have a friend who wishes to open and maintain some Access databases but has an old version of Access, and has just moved to Vista. He doesn't particularly want to have to buy a new version of Access.
Does anyone know of anything OpenSource, that will open and edit the databases? I don't believe OpenOffice's Base program supports them.
Cheers,
Steve
Which version does you friend have, most versions including the early ones have no problems with vista.
Think he's using Access 97.
Steve
MDB Viewer Plus
"MDB Viewer Plus is a freeware viewer plus and editor for Microsoft Access MDB database files. It does not require an install to run provided that Microsoft Data Access Components (MDAC) is installed on your PC (In most versions of Windows this is the case).
MDB Viewer Plus has been written to provide a free, quick and easy way to view, edit, filter, sort and search MDB files without having Microsoft Access installed.
This is very useful if you need to look at an MDB file but do not have Microsoft Access installed on your PC.
It is not yet a full database development solution but does allow you to view MDB files without an Access license.
Features:
Inline table viewing and editing
Standard search
Filtering records by fields
Sorting records by fields
Printing
Record view
Record count
Query - standard SQL select statements
Table Info (field types) plus printing of structure
Table Types
No installation required to run. (Provided MDAC already installed as part of Windows)
Exports to TXT, HTML, XML, DBF, XLS, WKS, RTF and PDF
Import from CSV,TXT,Doc,XLS,WK1,WQ1,SAV,DB,DBF,MDB,ADO,ADT,DAT,HTM,XML,WAB and VCS
Support Access 2007 Accdb files (Provided "Microsoft Office Access database engine 2007" is installed) "
That sounds spot-on Val, nice one :thumbup:
Especially as it sounds like you can do some basic editing and changes. I think he just has addresses etc stored, so nothing mega-complex.
I'll pass this on, thanks again.
Steve
