Module 17 - Adaption 10 Channel 3
Could someone with a VRS see if they can access Module 17 - Adaption 10 Channel 3? I've tried on my 06 VRS but it says error. This is supposed to allow you to change the trip computer accuracy.
Thanks.
Choose 16 Security Access and enter the login 13861 before going into 10 Adaption.
Thanks, I'll give that a try tomorrow.
Stu,
I tried your suggestion but the Security Access is greyed out.
Any ideas?
What version of VAG COM are you using?
Is yours a MKII or a very late MK1?
If it's a MKII the there lies your problem.
You need a CAN Capable cable.
If it's a MKI then you need to have a registered version to carry out adaptions.
There isn't a MKII VRS? Or have I missed your point? :confused:
Its a BLT engine if thats what you want to know.
Sorry for some reason I'd convinced myself it was an Octavia. Is your software registered or trial?
Going mad? hehe :)
Its a registered copy. Everything works as expected but this part is just greyed out.
Going mad? hehe :)
That and you assuming that all vRS' are Fabia's :D
Post up a full autoscan for us.
I was just testing you ;)
I will do a full autoscan tomorrow evening and post back the result.
Here's the auto scan, can't see any issues.
VAG-COM Version: Release 409.1-S
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
  Controller: 038 906 019 NJ
  Component: 1,9l R4 EDC 0000SG  7331
  Coding: 00102
  Shop #: WSC 13765
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
  Controller: 6Q0 907 379 AG
  Component: MABS 8.0 front  H04 0002
  Coding: 0002229
  Shop #: WSC 13765
Address 08: Auto HVAC
  Controller: 6Y0 820 045
  Component: Klimaanlage        X0840
Address 09: Cent. Elect.
  Controller: 6Q1 937 049 D
  Component: 0000 BN-SG.         1S34
  Coding: 25738
  Shop #: WSC 13765
Skipping Address 15-Airbags
Address 17: Instruments
  Controller: 6Y0 920 972 S
  Component: KOMBI+WEGFAHRSP VDO V03
  Coding: 28401
  Shop #: WSC 13765
Address 19: CAN Gateway
  Controller: 6N0 909 901
  Component: 003D GATEWAY CAN    1S34
  Coding: 00014
  Shop #: WSC 13765
Address 44: Steering Assist
  Controller: 6Q0 423 156 AB
  Component: LenkhilfeTRW        V270
  Coding: 10120
  Shop #: WSC 13765
Address 46: Central Conv.
  Controller: 6Q0 959 433 E
  Component: 60 Komfortgerát     0002
  Coding: 00019
  Shop #: WSC 13765
Address 56: Radio
  Controller: 6Y0 035 156 E
  Component:  Radio YD5          0015
  Coding: 00401
  Shop #: WSC 13765
End   --------------------------------------------------------------------------------------------------
I was trying to find the label file but I can't seem to find it on my computer.
As you are a registered owner I would suggest you email Ross-Tech directly.
OK, thanks for trying anyway
Some of the Octavia (1U) clusters do not support that channel.
Its a Fabia VRS, could it be possible it's not supported on that too?
Yep.
