Checklist for fuel Economy
I Decided to start this threat to have a one stop place where people can help themself to information if theyr cars are guiving poor gas eficiency
everyone, just copy paste and add to the check list and i hope this becomes a sticky :thumbup:
1. Air/fuel Mix and Idle adjustment
2. Valve Clearance (0.25 intake / 0.20 exhaust) <-1st item to check / set
3. Air & Fuel filters (must be able to pass light through)
4. Ignition/Spark Timing <-4th item to check / set
5. Temperature should be +/- 90c
6. fuel injectors / Carburator must be clean
7. Choke System, on injector model, Temp sensor/sender
8. Piston Rings (can be checked by compresion test)
9. valve seals (can be checked by inspectin spark plugs individualy)
10. Broken/Detached Vacuum hoses
11. Head Gasket seal (can be checked by checking water lever while accelerating {should drop})
12. spark plug gap (0.80mm) <-2nd itme to check / set
13. Spark intencity / Duration <- 3th item to check / fix
After checking 1st through 4th you;ll be able to check for everything elso, if not, you might get wrong readings
