Power steering controller coding
Dougal
I replaced the power steering pump today on our 2001 Fabia 1.9 tdi comfort.
The original pump had a coding of 00110. The new one came with coding 10110 already installed.
After reading the coding info on de.openobd.org - skoda - fabia (6y) it is far from clear whether the coding should be 10110 or 00110, (our roomster also has a pump coding of 10110).
The first 1 apears to be for the "airbag", but software levels apear to be involved as well (is this the sofware level of the power steering controller?).
Has anyone any further information on how to identify the correct coding?
Everything appears to be working ok with 10110 in.
Thanks for any info
Doug
the 6R label file redirects to the 6Q -
; VAG-COM Redirect File
; Component: J500 - Steering Aid (#44)
; This file is part of a redirection package,
; make sure you have all of the following files.
; 6R-44.LBL
; 6Q0-423-156.LBL
; created on 22/Apr/2008 by Niels Ezerman (NEtech VCDS/VAG-COM diagnosetester til VW Audi Seat Skoda)
; last modification: 22/Apr/2008
; requires VAG-COM 405.0 or newer
REDIRECT,6Q0-423-156.LBL,6R0-423-156-???
But the 6Q only has MBV's and not coding info.
Please post a complete scan from the car in question, we need to know which ABS system is installed and such.
Thanks for your response Sebastian, information as requested.
I have kept the information to a minimum and removed the end of the chassis number.
Doug
Chassis Type: 6Y - Skoda Fabia
Address 01
Controller: 038 906 019 AF
Component: 1,9l R4 EDC G000SG 1110
Coding: 00002
TMBHS46Y52331xxxx SKZ7Z0A098xxxx
Address 03
Controller: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V00
Coding: 00188
Address 08
Controller: 6Y0 820 045
Component: Klimaanlage X0760
Address 09
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25754
Address 15
Controller: 1C0 909 601 C
Component: 02 AIRBAG VW51 01
Coding: 12338
Address 17
Controller: 6Y2 919 880 D
Component: KOMBIINSTRUMENT VDO V09
Coding: 16441
Address 19
Controller: 6N0909901
Component: Gateway K<->CAN 1S31
Coding: 00014
Address 44
Controller: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10110
Address 46
Controller: 6Q0 959 433 C
Component: 0F Komfortgerát 0003
Coding: 00066
Address 56
Controller: 1U0 035 161 D
Component: Radio GRO 0001
Coding: 00401
End
