Can anyone help with some approximate costs?
Hiya :)
Just wondering if someone could tell me what i'm looking at paying for...
  • Gearbox oil change
  • I was told a bush on my anti roll bar was "cracked". new anti roll bar?
Just had a new clutch fitted but i still think the changes are a little lumpier than i remember so hoping a gearbox oil change will help
Depends where you go, but fluid change will be 50 quid or less. And if its just a cracked bush then it will only be the bush that needs changed, not the whole ARB. That might be more like a 100 quid job.
Those are just very rough guesses but are probably the most you would pay. . .
Just found out the bit thats cracked is a sleeve or something? requires a new arb. Guy said theres a revision to the part which does away with the plastic bits and has slightly bigger diameter bushes and thats what i'll be getting :)
Said 270 for the new arb fitted, and they'd do my gearbox oil for free. booked in on the 22nd
