changing my felly injectors
can any one help i got a felly 1.6 MPI the injectors isn`t so good so i am planning to change them so any one can tell me if i need to change the injectors do i have to go for the the stocks or any one got an idea for new ones that can improve the performance of the car?
i am sure you will help me guys thank you.
have you tried an injector cleaner i have the 1.3 mpi running a bit sluggish stuck some redex through and running spot on now.:thumbup:
i wouldn't bother fitting uprated ones, besides from that the fueling would be wrong if you did..
if you need them i have a couple of sets of the oe ones floating about here
From what i can remember standard injectors can handle something like a 35-40% increase in power anyway, So replacing them with performance ones would be a waste of time unless you have some serious mods to go with them. Your best bet would be to try using injector cleaner in your fuel tank or remove injectors and have them ultrasonic cleaned which can make them feel like a new set as well :thumbup:
ok tom can provide me with these sets
