Problem with lights
Hey Guys,
Im having a problem with my lights. One of my dipped beam lights, on the driver side, is not lighting up, despite having replaced it with a brand new bulb. In conjunction with this, when indicating right, (same side), the indicated flashes at almost double the normal rate. This only occurs when the dipped beam is on. When i flick my full beam on, indicating carrys on at its normal expected rate. As i said i have replaced the bulb that is not lighting but this seems not to be the root of the problem.
Any ideas where i should try next?
Kindest regards,
2012
try changing the relay mate! that could be the prob!
how is that done?
the dipped beam is still not lighting up on the drivers side, despite replacing the bulb with a brand new one.
2012
p.s. the dipped beam worked up until yesterday, i havnt done anything to it, it just stopped working!
