+30/+40 mm springs?
No, there's no mistake :)
I was wondering is it possible to raise my Roomy a bit with some special springs? Or something?
Does anyone know something about this?
Thnx :thumbup:
Someone who tows/caravans should be able to advise on this better.
To my knowledge there are none specific to the Roomster and through some searching I have only really found springs to raise 4x4's.
You may want to try a local specialist
May be a silly question, but why? Air suspension units may do the job. A friend had them on an Astra estate a few years ago. Often seen on "Pimp my ride"!
The reason is that the Scout Roomy is not as big of a scout as I want it to be :) I'm also driving Ford Fusion and it is much more nimble and practical in and outside a city. Going on and off the curbs, over the rocks and pits, etc. with Fusion is no brainer, no hassle at all. Yet with the Roomy I have to pay close attention what I'm doing with the rear axle. In fact I had to remove the mud flaps because they would hit any curb taller than 3-4 cm! Even my Octy isn't that sensitive! To cut the long story short, I would be perfectly happy if the Roomy was just a tad higher.
Edited by Marko3
The reason is that the Scout Roomy is not as big of a scout as I want it to be :) I'm also driving Ford Fusion and it is much more nimble and practical in and outside the city. Going on and off the curbs, over the rocks and pits, etc. with Fusion is no brainer, no hassle at all. Yet with the Roomy I have to pay close attention what I'm doing with the rear axle. In fact I had to remove the mud flaps because they would hit any curb taller than 3-4 cm! Even my Octy isn't that sensitive! To cut the long story short, I would be perfectly happy if the Roomy was just a tad higher.
May be obvious, but why are you driving over kerbs + rocks big enough to rip the rear axle? :confuse: It'll all end in tears that will.
I had this problem with previous car (peugeot 206 SW). It was an excellent motor, but the mud flaps scraped the ground with 2 people in the back, let alone with the trailer on. It had torsion bar suspension, so was nearly impossible (AKA very expensive) to fit spring assistors.
Steve.
