MAF Sensor
Hi Guys
I think I may have a MAF sensor problem !
Can any one say what symtoms you get with a faulty sensor ?
The car is a 05 fabia 1.4 TDi (75)
Many thanks in advance
Radiotwo
limp mode , lack of power
try disconnecting it , if it runs/drives better, then the MAF is probably faulty
Thanks for the reply Ric
I have tried unplugging it, and it did not make any diffrence,
My symptoms are: I need to put the pedal all the way down to the floor before I get any
performance
Radiotwo
need to get the codes read , as there maybe something else wrong other than the MAF
Hi again
All ready used Vag-Com and no fault codes.
But I have removed the MAF from the car, and blown air through the maf and seems a lot better.
I would not say perfect but 90% better
Radiotwo
