F@#king turbo's
Thats the second in 6 months
Anyone got a hybrid forsale or no where to get a cheap one??
cheers
regards
shaun
just a thought mate, get it remapped again to put less stress on the turbo??????
seems like you askin too much there mate.
all the best gettin her sorted.:(:orb_sad_2
billy
Whos mapping are you using, as with 170hp the stock pd130 turbo should be OK? I'm worried it's boosting too high / too smokey. Do you warm it up first before boosting / let it cool down a bit before switching off? Cheapest hybrid will be around £800 which will get you a stock pod130 turbo with modified internals good enough for a reliable 210-220bhp. However, on a pd100 engine, I'm not sure this is possible target. Maybe. :)
it should definately be possible im sure, as hes already using PD130 injectors and turbo which im sure are the only differences between pd100 and pd130? oh and he might need a front mount to get that sort of power, id have thought 190-200 with hybrid then 210+ with FMIC.
Nope they are not the only differences - which is why Jason swapped in a PD130 engine etc at some stage as the internals of the PD100 are not as strong. I can't remember which exact bits are different, and a *lot* of them are the same, Jason will probably remember :)
TD stage 2, can get it for 900ish. PM if interested
