vRS retrofit cruise control...?
Does anyone know, is it possible to retrofit a cruise control to a diesel vRS?
How hideously does it cripple your fuel economy if you run on cruise control? I can't decide if it would be super efficient or if it would just lazily blast fuel into the engine...
Yes it is possible, it should help fuel economy on a run.
if youre heavy footed it will help, i personally found its only good to keep my speed within the limits on a long journey on a motorway (an economy on there too) on most A roads i find i can get better economy by being a bit light footed than the cruise control.
I had it retro-fitted by a member on here to my Fabia VRS! Its great no extra fuel loss! :thumbup:
yes, although you will need a stalk and a steering controller module unless you have maxi dot
I have 2008 vrs tdi with trip computer, and despite postings on here that it doesnt need a steering controller, it does, as it doesnt have maxidot!
so
Stalk £65
controller £110
plus vat and labour= £250ish
from a main stealer obviously
There are a few people on these forums who will help you out.
One of the great chaps here did my Octy vRS for £150 all in.
same as above :thumbup:
w00t. Cheers guys.
so
Stalk £65
controller £110
Maxidot is not the deciding factor on the Steering Controller. I'd be 99.9% an 08 vRS TDI would only need the stalk.
