Headlight washers
Can any one tell me whether the headlight washers on a fabia run off the same pump as the windscreen washer pump.
I find that i am constantly topping up my washer bottle as it only holds 2 litres, and wondered whether the 4.5 litre bottle used on cars with headlight washers is a direct swap?
At
Its a seperate pump.
You can buy blanking grommets from Halfords and other car supply places. Just silcone seal it in place.
Silcone. Great stuff :thumbup:
While we're on the same subject:-
Do the headlight washers only work when the headlights are on?
Or do they work whenever you operate the windscreen washers?
Separate pump for windscreen & headlights, but are there separate reservoirs?
with lights only, hold the spray and it sprays the windscreen then after 1 - 2 seconds it sprays the lights so you can choose whether to spray one or both. must admit to being absolutely confused when i first started spraying my windscreen, i thought my lights kept dipping, i give myself a smack for that one
Only work when Headlights are on.
Beat me to it. :)
At
A bigger bottle would be wonderful. I did mean to ask my dealer about it a while ago but forgot.
I'd appreciate any details anyone has.
4.5 ltr fluid container for vehicles with headlight washer system and water level
indicator
Part Number: 6Q0 955 453 T
indicator
Dave,
Yeah i'm gonna get one, but probably won't have enough time this weekend. If you do get one can you add a note to this thread with the grommet size required to blank off the spare pump outlet.
Cheers mate
Dave' date='
Cheers mate[/quote']
Will do, also I will try and get a set of photos of what is needed to do the job.
Dave
Looks like it might be fun getting below the battery .... lots of scrapped knuckles or a half stripped out engine bay!
Thanks for the info :thumbup:
Best way to get to the washer bottle is to whip the front bumper off.
Will follow this one with interest... Please can some post a guide to how it was done, because I thinking the front bumper must have to come off yes?......
