Make leather steering wheel more tacky ?
About the only complaint I have of the Fabby is the leather steering wheel is pretty slippy (more so when cold weather about).
Anyone use anything to make the wheel a bit more grippy ? (no rude suggestions please :rolleyes:).
Raspberry jam?
Raspberry jam?
I mighta known :P
swap it for a Clio 182 steering wheel. Mine partially melted from the heat and became incredibly sticky. It's a common fault apparently
Give it a good clean, the only times I have problems with mine is when it starts to absorb all the oils from our skin. A good clean using lightly soapy water only should sort it out. Do NOT use a leather cleaner or conditioner on your steering wheel, it will make it even more slippery.
driving gloves?
Taa, Manyo. Will give this a try.:thumbup:
Have never used leather cleaner or conditioner, only sometimes wiped rim with excess from upholstery cleaner.
And, yes, resorted to wearing leather gloves at times in cold weather - but don't like them really.
Similar to Mr Newman, but I managed to get one in black. There is no substitute for proper grain leather on a steering wheel!
I echo the driving gloves suggestion.
Sandpaper
Shark skin?
double sided sellotape, you become very stuck to the idea.
Should one of the Mods make this thread a sticky?
Coowee :D
