Storage box behind rear seats (umbrella tray)
Happy Easter to all.
I'm the owner of an Octavia Elegance 1.9 TDI , I have a problem with the umbrella tray behind the rear seat.:thumbdwn:
This part is inserted in the side rails , during car running fall down , making a very high noise.
Inside the tray I have only an little umbrella (less of 3 Kg. that say the user manual).
I'm doing a wrong thing ? Any suggestions ?
Thank you very much for your help.
Mariush
Welcome to Briskoda :)
Is the sliding cover fitted behind it? The cover locks in and secures it in postion. Without the sliding cover fitted I think the umbrella tray could fall out.
I have one in my L&K estate and I've always had the sliding cover fitted and its never been loose or fallen out.
I'll go out and double check mine a bit later on.
Nothing to do with your problem, but I only found out I had this tray yesterday. Just need to buy a brolly now. :thumbup:
Mine has high vis vests and other such junk stuffed in it :rofl:
i've got one spare if any one would like one?
Now i did not know i had one so got to go down the garage now (in the rain) to find out. 55 plate Elegance 2.o.
Not one on mine, 55 plate A2 Elegance.
There is not one on mine 55 plate A2 Elegance.
Yes please if it will fit my vRS. :)
My 55 plate 2.0tdi Elegance has this tray, so yours should as well.
I keep my baseball bat in there.
It should be between the front of the tonneau cover and the back seat. Mine has a little cover that lifts up and his held down by a magnet.
Yes its on the estate :)
Probably why I can't find mine then! :rofl::thumbup:
That'll be why then ;)
if yours is a vRS estate then yes, thats what it came off, if so PM me and we'll sort it out
Thank you to all for your help.
I have always the boot cover in place , today I try to remove the cover , reinsert the umbrella tray checking where I can do something wrong.
Mariush
Bugger - mine's a hatch :(
I didn't realise it was for the estates only.
Can it be made to fit the hatch?
Wouldn't think so, the mountings are different on the hatch (I've had both)
