estelle 130 reg E447 WHF
Ive just bought one and im trying to get some idea of history and mods:D
i guess its been a road rally /track day car in the past
anyone know anything about it had a hand in its mods even know a engine spec :confused:
looking forward to getting it going and a mot then rolling restoration :thumbup:
thanks
I am guessing from your username that you may be from Cornwall ....so
Mid Cornwall cars tuned a few of the older cars...but I am not sure if they ever kept a record of it ......
thanks for reply
I am indeed based in cornwall
the car seems to have come from lancs via birmingham and plymouth
were are mid cornwall cars based and i will ring them anyway
sine first post have now found it has vented discs at front is this normal or are they a mod too
Edited by cornishwrestler
more info
They were based at Roche ...but have since closed and mostly moved/joined with the Skoda dealer in Penryn so someone there may remember if it has been through the workshops at any time.
If its got vented brakes then thats a modification. Estelles only had solid discs in production form, yours will have the 4 pot callipers with 4 brake pipes off them if it has production based brakes....come people spaced the standard caliper to fit vented discs.. What else has it had done?
engine has a single 40 dcoe weber ashley exhaust electric water pump facet g someone wil;l know the car of old and can confirm exactly whathas been done and fuel pump and seems to have a high lift cam of some sort.
seems to have stiffer springs/shiocks
on the down side it has a major oil leak from the front of the block , suspect the crank oil seal and the ignition electrics ahve just gone into meltdown :(, luckily a friend is an expert auto electrician,:thumbup:
the plan is to use it for some classic trials , the lands end trial has been a long time ambition i plan to fulfil next year
im hoping someone will know the car of old and will be able to tell me more :)
Not known to me. I'd suggest trying to track down previous owners, because, whilst not a GpA spec (needs to retain standard Jikov and manifolds) this could well be a high spec race or rally engine, but you need to know what pistons, cam (maker and profile) and jetting it's running?
Also, are there any signs of it ever having had a rollcage, or sill strengthening (one period mod was to add the beams from the Rapid cabrio, which aledgedly just slide down the sill boxes).
Although I don't recognise the reg.no., I'm pretty sure I supplied the discs for this, and probably the spacer kit for widening the standard 4-pot calipers.
The ('Davis-Craig' ?) electric water pump rings a very loud bell, but not loud enough to put a name to the owner. Try the same info request on skoda-forum, I'm confident someone with a better memory than me will remember it !
Thank you for the info :thumbup:
have tried skoda forum as well no joy yet
discovered a small green plaque in the glove box showing attendance at a skoda meeting at Donnington park in 2003
and the original dealers sticker is for a dealer in st helens
aome photos :thumbup:
Looks nice.
I remember this car, it had 4 pot calipers with vented discs, an uprated clutch, sachs group A I think, ashley grp A exhaust, elec fuel pump and water pump, gas flowed and ported head, kent cam, spax suspension, 135RIC box and a weber DC40. Also has a 136B favorit engine, Lumenition ignition and lightened and balanced bottom end, lightened flywheel
The car was located in Devon and was quite rotten underneath from what I remember.
The engine if it is still intact with all those bits would be a sound basis for making a really well tuned Estelle, good luck with it!
Edited by Skoda-Msport
I think it was used for road rallies, I remember a car like this from a few years back. Try the web forum that Skofast recomends, because I think the guy use to go on there.
Looks cool! I would love an old rear engined Skoda to scare some of the youngsters!!
there's a fairly sporty one that used to live near QA Hospital in Portsmouth (I don't work over that way any more, although do spend quite a bit of time there recently!!:lol:)
thanks guys all the info is really useful :)
the only thing missing from the description is the luminition just points now:(
and the other thing thtas missing is the under side being rusty releived to say it looks sound :Dhopefully the mot man will agree
now im going to be thick :mad: whats a ric gearbox
RiC was the catalyst-equipped 135 Rapid, its gearbox had the same 5 ratios as 130 saloons and normal Rapids but the lower 4.22/1 final drive ratio as per 120s, hence better acceleration but lower top speed
brilliant thank you
and ideal is the final aim is to take part in classic trials lower gearing is going to be much more important than top speed:)
