removing door trims and rear speakers
how do i remove door trims (front and rear)?
What size speakers can i fit in the rear doors and do I need a speaker adapter ring?
Start from number 5 then 6 --> 7
Extra help from JonA
You are supposed to remove only the outer part of the "handle - number 5". The clips that hold the outer part are quite stubborn, and require a bit of violence before they give up.. When the outer part of the handle is of, you will find two T30 screws under it which you must unscrew.
Now you are able to pull the door card, be gentle ;)
Then remove 4 and 8...
You will see this :)
Speakers are riveted, you need to drill them...
These pics are from Roomster, but they resemble to Fabia...
Edited by irfant
thanks very much for the pictures but what is no. 8
3rd link doesn't work, what will i see
Electric window switch..thing
fabia55-number 8 is the button electric windows.
