please help asap
hi guys and girls. i need urgent help please, lent my vrs to my girlfriend as hers in in the bodyshop and she thought shed be nice and fuel my car up.....with petrol!
any way she drove 5 minutes or so down the road and it cut out, can anyone help me?
btw she put 18litres into it on a near empty tank.
thanks, stephen
There are various threads on this subject. To start with you need to drain the tank, some people seem to get away with filling up with diesel, fuel filter might need changing.
thanks guys, do these engines normally start after doing this?
Hi mate depends usually damages the pump!
Fortunately Fabia VRS has a PD engine which only has a low pressure electric lift pump. Damage to the fuel system is highly unlikely, especially as the almost neat petrol mix meant that the engine stopped as soon as the mix reached the injectors (as diesel cant run on petrol....)
Its just a case of draining the tank and fuel filter,fill up with diesel, and crank the engine till it starts (it may take a minute or more of cranking). It should sputter back to life, albeit, it may cough and splutter for a few seconds while the the last dregs of petrol are cleared.
PD engines are much more robust than CR engines.
she lives :)), drained the system out, new filter from skoda (£21) with discount . started first time, lots of smoke for a second and some half dieing animal noise then the perfect sound of chug chug chug chug
thanks for your help guys.
stephen
