Wheel offset
Is the Fabia 1 and Fabia 2 the same wheel offset? :confused: Seen some really nice standard fit 16's on a brand new furby and thought would look decent on mine.. Also, is fabia 1 and seat ibiza the same??
Cheers guys :o
The offset will be on a par with each other, but IIRC the pcd on the fabia 2 is different. Fabia 1 and Ibiza not the same but share a lot of components
as rigsby says I think the offsets are on par with each other but the holes will be in a different place as they have a different PCD
Fabia 1 and Seat Ibiza are a straight swap although they have a smaller offset so will be set back in the arches - i had a very similar thread http://briskoda.net/fabia-i/seat-alloys/139568/
HTH
HTH
smaller offset wheel sticks out more..bigger offset wheels go in more.
Is the PCD different? Didn't Leon (LYK) put some Roomster wheels on his fabia at some point?
I was under the impression the new Fabia was mechanically very similar to the old one?
Course, I could be (and most likely am) wrong ;)
:doh: i knew it was one way or the other - they'd look wierd though :D
Edited by PastyBoy
Cheers for the link pasty. Have been offered a set of Ibiza Cupra alloys so might try them and fit spacers if necessary. If no good them will keep huntin for those furby 2 alloys. Think they are called 'Atria' or something..
