skoda vrs engine mounts
i have had my car remaped to around and about 180bhp the car is great but my engine mounts have gone really loose. we had all the mounts replaced about 2 months ago and now i am left with the same problem.. i dont want to waste more moner on mounts that pop out after month.. has anyone had the same problem and how did you go about getting it sorted????? wb regards Rob
Welcome to Briskoda, might be a idea to post this query into the Fabia 1 section.
Thread moved to fabia 1, welcome to the forums
Hello, who fitted the 'new' mounts this time round? As id say its almost impossible for you to knacker a full set of engine mounts in a month or so.
I sheered (sp?!) off the drivers side mount on the engine in Sept. down @ Santa Pod last year, replaced it myself and its still going now and mine has seen some abuse.
However I believe there are two mounts than can be uprated on the 1.9 engine, one is the dogbone mount, not 100% sure on the other if im honest.
Also, be aware that the gear box mount under the battery is a known weak spot that Skoda issued a service bulletin about telling service engineers to just grease up if not physically broken to stop the knocking noises .
