mk2 k04 20vt project
immobiliser allready done mate,not going to be using the mk4 clocks at all,just collecting all the relovent bits i need at the moment to run the mk4 hydraulic box :D
Good ,
looking forward to seeing the end result
Tom
Good ,
Tom
unfortunatly due to me not being a rich bloke its all going to happen quite slowly :rofl:
Get working faster then!
Surely you get a load of cash for doing Mock The Week?
thats whats paying for the new yeti!!!!!!!!
Your latest DVD is selling quite well too... should be able to get it done soon ;)
  • 11 months later...
Nice, Love them RH Classics, good to see you go to the ring you on Northloop?
great project m8 ;) .... that cars gonna fly with that engine in lol ... rob the other car isnt as shiney shiney as urs and dont have those lovely MAK'S MMMMMMMMMMM lol
  • 2 months later...
Evening lads
I was hoping to get ye're advice in relation to an issue I;m having trouble with a 20vt conversion.
I have the engine cranking and it's sending spark to all four plugs
and its trying its best to start but i don't think the injectors are sending fuel in.
I hooked up a pump, and i was getting fuel out of the return and pressure at the regulator.
I wired in the diagnostic plug this eveing and received the following list of faults.
I've included everthing i got, just in case there may be any symptoms of anything.
P0238 Turbo boost sensor (A) circuit high
P1237 Cylinder 1 Fuel injector circuit N30 open circuit
P1227 Cylinder 3 Fuel injector circuit N32 low
P1228 Cylinder 4 Fuel injector circuit N33 low
P1226 Cylinder 2 Fuel injector circuit N31 low
P1426 Evap system open circuit (Removed and will put resistor in)
P1548 Solenoid Valve N75 open (not connected yet)
P1118 heater circuit Bank 1 sensor 2
P1531 Intake camshaft control circuit
P1432 Secondary Air Injection (Removed and will put resistor in)
P1287 Turbo recirculating valve N249 (removed and will put resistor)
P1501 Fuel pump relay J17 short to ground (I had no fuel pump connected) I just used a gallon of juice and a mk4 intank fuel pump and a seperate battery.
P17931 Crash signal from airbag control unit (Expected)
P1650 Missing message from instrument cluster (Expected)
Was told to monitor pin 83 of the ECU . If the injectors were fueling correctly it should give 12V's and then drop to 1V , but i have a constant 12V
Greatly appreciate your opinion and any assistance
