EPC Light
Hi guys 2day in my vrs a light came on so i looked it up and it was epc light what do you thing the problem is the car drives fine
thanks
Guys is there a way to reset the ecu or do i have to take it to the dealer
:) I think that's the yellow traction control light isn't it? If you can't switch it off by the button on the dash (with the heated rear window & fuel flap release) then it's usually a hub sensor fault. You'll need a diagnotics check to find which one tho. Do you know anyone with a VAG.COM? :thumbup:
na its not the traction control light its diffrent. I cant find a pic il take one 2maro
:o Sorry! It was the ESP light I was thinking of! :rolleyes:
Have you checked your brake lights?
yep its working.
this happen day after i replaced the asr button on the dash. the old asr button blew the fuse and then a replaces it and then 2day this light came up
