Audi TT 6 spokers replacing 17" Octy's
Just got a beaut set of these off Piston Heads but I'm not too sure I like the centre caps - too big. I'd like to replace these with caps which will fit into the centre hole. My intention then would be to remove the Audi circles from these caps and fit 55mm resin dome Skoda Auto stick-on centres same as I have on my existing wheels - 17" mk1 Octy spiders. Unfortunately, the Skoda centre caps are too small at 55mm dia.
So, to get to the point; does anyone know the part no. of the Audi centre cap which fits?
Or, what model of Audi, if part no. isn't known.
Sorry I can't be of more help but...does this mean you'd be flogging the Octy Spiders...?
Are you talking about Avus-IIs here Ming? As in from an 8L-shape S3?
Photos please and help will be provided :)
Steve
if the centre caps are too big surely smaller ones won;t fit in the same hole anyways? :confused:
however if its the 55m Skoda badge that is too small i can get whatever size badge you need made up :thumbup:
I've had these wheels before, they are TT 6 spoke Ronals.
Have a search for larger Skoda badges they must be for sale somewhere. You can prise off the audi ring logos and clear silicone the Skoda badges onto the brown plastic centrepiece which should be thoroughly cleaned of course.
Ah right, the ones from base-spec TTs - with you :thumbup:
These ones....
Steve
Edited by Wardy
Can I ask why though Ming? The Spiders looked so much better :(
Steve
They look a lot like the Octy II Vega, wonder if the caps off a set of them fit?
These ones....
Steve
They be the ones.
I see Pastyboy is after some extra cash for his Track days. Would be a good idea ming as he could customise them if you like.
