Acceleration whistle getting louder. VRS Fabia
giandougl
Hello One and All,
Getting a loud whistle from engine compartment when car is quickly accelerated.
Must be an air-leak (I'm guessing) but where should I look ????.
Subject open to all for your input.
Thanks in advance.
Ian. 15/09/2009. :D:thumbup:
Ian, that will be your turbo whistling.
In itself, its nothing to worry about, and normal. But if the noise has changed significantly or become noisier recently it might be worth getting an opinion from your local garage. There have been instances of Turbo failure.
This doesnt mean there is a problem with yours, mine always whistled on acceleration. Just piece of mind.
RBW
I have a constant boost leak in my IC pipe coming after the turbo bend, you can definately define whether it is air leak or a whistle. All derv turbos whistle, some more than others. If in doubt get it checked out i guess. If your mechanically minded you could bolt it off yourself and take a quick look. Bit of a pain to do though.
