boost upgrade
hi all, installed a boost system into the car the day!
basicly just a spinning nut system with a ball bearing and spring!
added the system to the correct pipes etc and sorted it to take boost up 14psi
took the car out a proper run and nothing different had happened.... no big increase in anything
dv got louder :rofl:
so i take that the wastegate is controled by the ecu? and that you have to chip it to increase the boost?
is there not away around this as i aint got funds for a chip
thanks all
take the n75 plug on top of the induction pipe controls the flow of boost?
can you not bypass to increase the boost and not go into a lot of money??
Chris, you have a PM
