2.0 PD140 turbo weird noise
I bought it for �30 direct from the innotec warehouse in Salisbury.
It was not too hard to use although there's a marmon clamp instead of a bold on exhaust. It's hard to get much clearance between the box and the exhaust, but I managed. My only tip would be run the hose right up in there, get it right inside, I lost some of the fluid due to a badly angled spray nozzle/hose, so it might be worth doing again. I've never touched an engine much before, I suggest downloading pictures of the turbo and engine to provide familiarity with the engine before getting under the car. However, as a novice I had the turbo clean kit in, EGR cleaned and throttle body cleaned in about 4 hours.
My choke noise not gone, I certainly may do the kit again after it's had a service and been vag-comed for fault codes, but there's more boost, still a gap in the middle. Like boost, flat, boost. The rpm's are lower overall, some real improvement.
Hope that helps. If I find the cause of the cough cough noise I'll be sure to report back.
Does anyone have any pictures of the engine where the turbo is etc or better still any pictures of actually using this cleaning kit? Is there any gaskets to replce if you have to take off the exhaust..? Sorry it's been some years since I worked on a cars Engine - I have no idea where to start on this one.
thanks.
Rob
