Major service and cambelt change...
My 55 plate Fabia vRS is due a service and cambelt change - mileage is 33k.
I've been quoted £385 from a local (trusted) VAG specialist - the breakdown is as follows: £150 for service, £200 for cambelt, £35 for water pump.
Does this seem about right?
Cheers,
Neil
Sounds like a result to me! My 50K service and Cam-belt Change at a Dealers in Bedford cost me £660, and for that they also lost me my aircon cap, ignored three emails, then told me they had posted the cap three times and it still hasn't arrived. Next service I will be going independant too...
That's a bargain, I posted on here about local main dealer quoting me £290 for cambelt and £35 for waterpump.
Biggest factor is the "trusted" word! Coupled with the decent price, it seems ideal.
:thumbup:
In all fairness, I think that losing the dust cover from the A/C service points seems to be "par" for the course as far as A/C industry is concerned - I can't say why it should be though! Keep at them as they could always buy in some new caps (most likely they will "get" one from the next car in - or isd that where you one went to!).
Where abouts are you?
Warren
that seems like a good price to me... I've just been quoted as follows: -
A timing belt change, including the belt, tensioning roller, damper, relay roller, coolant pump and auxiliary belt is: £313.06
A full Service for the same vehicle is approx. £145 all inc.
I almost feel like they're trying to rip me off now! This quote is from the derby area by the way...!
I've posted on your thread but:
Timing belt kit £90
Pump £35
Aux Belt £10
= £135
3 hours labour @ £40+ VAT = £138
Total = £273
Therefore £313 isn't much above the base price I work on...
Its not a cheap job to do sadly and the timing belt kits for these engines aren't cheap really for a belt and few bits.
Hi Neil.
I have just had my 5th annual service done including cambelt change, new water pump, rear washer re- connected (yet again!) by a local VAG specialist for �364 which I think is reasonable and your quote is similar. Don't think you will get it much cheaper using genuine Skoda/VW parts.
I've been quoted �385 from a local (trusted) VAG specialist - the breakdown is as follows: �150 for service, �200 for cambelt, �35 for water pump.
Seems like a good price to me.
just had my 60K service, oil change, cam belt and water pump . . . £300 all in.:thumbup: Garage called C&R, Thorverton, just outside Exeter if anyone local is interested.
just had my 60K service, oil change, cam belt and water pump . . . �300 all in.:thumbup: Garage called C&R, Thorverton, just outside Exeter if anyone local is interested.
60k? is that all youve done? dont you drive it that much?
I've been quoted £590 for a cam-belt and Water pump from a VW dealer and for basic service £360 Rip off Never go to a VW stealer
Edited by Guest
