camshaft sensor
Hi IEP,
You could be right, after scanning, taking it round the block (2 min drive), both fans were running, however the lower hose was much cooler than the top one. I think he needs to find out if the water pump has ever been changed.
Peter
Hi Peter,
Interesting info, if the hoses are at very different temperatures then that does point towards the thermostat. If the pump has failed, the water flow will be reduced but the temperature of the hoses should be the same.
Having said that, If it has been over 60k miles since the last waterpump change then that probably needs to be done anyway.
iep
i am going to go this way,sort overheating problem then try to sort camshaft/whatever problem:D
change thermostsat and maybe engine temp sensor 1st to see any links/pics will help
then water pump
thanks everyone for help
1st scan
Wednesday,28,October,2009,20:53:01:42583
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11500
Work Shop Code: WSC 10001
Additional Info:
3 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
P0012 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
Readiness: 0000 0000
2nd scan
This was the second scan (auto-scanned the whole car), I did after I cleared the engine error codes and you drove the car round the block.
Peter
Wednesday,28,October,2009,20:59:45:42583
Data version: 20070723
Chassis Type: 1U - Skoda Octavia
Scan: 01 02 03 08 15 16 17 19 29 35 36 37 39 46 56 76
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Part No: 06A 906 032 HN
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 10001
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1Ux-907-044.LBL
Part No: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31480
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 1C0 909 601
Component: 0F AIRBAG VW51 0004
Coding: 12358
Shop #: WSC 31480
Address 17: Instruments Labels: 1U0-920-xxx-17.LBL
Part No: 1U0 920 911 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 19412
Shop #: WSC 31480
TMBER41U838677095 SKZ7Z0B1564878
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Part No: 1C0 959 799 B
Component: 3Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31480
Part No: 1U6959802D
Component: 3Y Tõrsteuer.FS KLO 0004
Part No: 1U6959801D
Component: 3Y Tõrsteuer.BF KLO 0004
Part No: 1U0959811D
Component: 3Y Tõrsteuer.HL KLO 0004
Part No: 1U0959812D
Component: 3Y Tõrsteuer.HR KLO 0004
1 Fault Found:
01038 - Central Locking Thermal Protection
35-00 - -
Address 56: Radio Labels: None
Part No: 1U0 035 161 D
Component: Radio GRO 0001
Coding: 00407
Shop #: WSC 31480
Address 76: Park Assist Labels: None
Part No: 6Y6 919 283
Component: Einparkhilfe 0001
Coding: 00103
Shop #: WSC 31480
Edited by fatty5000
Edit chassis number etc
I'd scan it again after a few days.
It needs time too find any faults if they re-occur,
And I've edited out your chassis number :D
HTH
going to do thermastat and temp sensor
thanks to those who replied to my posts
finally got round to changing the thermostat and overheating problem solved thank f..k
been driving around and car seems fine,engine management light is still off !!! abs light comes on after x miles but always goes of when turning car on and of
am going to try and vag com again and hopefully sort faults:)
Hi Peter,
iep
was thermostat thanks
Glad you got it sorted mate, now enjoy the car. :thumbup:
Peter
