Fabia Rear lights
Can the revised rear ligh design of 54/05 fabia vrs fit on a 53 plate vrs? thanks Glenn
yep straight swap
do you need any extra bits, likebulb holers etc ? thanks
Nope, like for like :thumbup:
Straight swap, Done it Twice. Should take about 20mins to complete.
One tip though get a 10mm Flexi head ratchet spanner....
Makes life a wee bit easier, You'll still knacker your knuckles though;)
sorry to start this up again, but wil any fabia rear lights fit are tey all the same ordo they have to be of a vrs originally, also how do you go about getting them off. thanks Glenn
Any Mk1 Fabia Hatch lights will fit (Pre or post facelift) , to get them off you have to remove the lights from inside the boot, behind the carpet, 4x10mm nuts and roberts your fathers brother.
As Bigw2069 says.
There is a guide here <-----clicky:D (part of which deals with the removal of the rear lights) that should give you a better idea
HTH:thumbup:
  • 6 years later...
Does the same apply to the estate models (51 plate)?
Edited by King John
