Not starting
I went to start my Felicia this morning and when I turned the key there was a clicking noise from a relay and no turning of the starter motor. Would this mean the starter motor has died or something else?
Everything was fine last time I drove the car a couple of days ago.
All lights were off.
Considering the age of the car it could also be worn bushes on the starter motor.
Try giving the motor a few good firm whacks with something like a soft faced hammer or a piece of hardwood to free any dust between the bushes and the spindle.
If that cures it then it is likely that the motor needs reconditioning.
Otehrwise, it could be a faulty solenoid (if one is fitted, I don't know if that is the case) or a flat battetry as Simbo99 says
HTH
I will have a poke around this evening and see what happens.
The battery was flat and after charging it overnight it started this morning.
We all bow down to your magnificance :bowdown1:..........................................
..........................1 out of 5,006 is a hit rate to be really proud of :moon::P
