Lemmiwinks
Anyone managed to get Lemmiwinks to work with the Fabia? Been trying all morning, taking fuses out etc but it still wont work. VAG-COM works a treat and managed to get auto locks activated :D
From what I've found on the web, taking fuse for the instrument cluster is supposed to help it work but it makes no difference.
Pls help
Timo.
Lemmiwinks is for 1.8T, not diesel as far as im aware..
Kev
Have a 1.4 petrol.
I've used it on a 2.8 6 4motion bora in the past with nice results. Had to pull a fuse out to get it to work with that.
I've read that already.
Think I'll give up. Will just have to accept that I cant make it go faster
Kev
iirc it's only for bosch ecu's, the block/channel arrangements are slightly different on the siemens and magnetti-marelli ecu's
lemmiwinks wont make you go faster, all it will do is give you the opportunity to ruin your engine by not understanding fully the adjustments you are making... extra power is not free
I think that's probably a wise plan.
