Abs Light & Traction Control illuminated on Dash
Fabia1 Vrs.
The Traction control light & The Abs light are both illuminated on the dash.
You can also feel @ very low speed, the feeling like the Abs is activating ....
The Esp buttton no longer works, But i take it this is built in by design ?.
Funny how it just started today after raising the coilovers, The lamps also went out for a short period of time after the car was turned off & re-started driven, Stopped the car again & the next journey it was back on....
Faulty Abs sensor maybe ? How many Abs sensors does the Fabia1 have ?
Brake fluid level is fine & from what i can see in the dark, everything appers to be attached :confused:
Dean
When I changed the front brakes on mine, I accidentally bent the ABS sensor rotor, (a disk behind the brake discs with loads of slots in it), at about 5 miles an hour while slowing down, the ABS would have a **** fit and the ABS would start.
My first port of call would be can you hear what side the ABS is effecting, mine was noticeable on the side I had bent the rotor, if not, its checking the rotor is ok, free from crud and the sensor is ok...
Worth a check....
4- one per wheel. You may want to consider a VCDS scan.
I did think as much.
Light's are currently off, I'll get it scanned & see what codes are in there.
Dean
