Our Stage 3 Diesel Turbo Kit
Jabbasport
Hi Guys.
Here's a power graph of warwick hunt's Fabia vRS with our stage 3 diesel turbo kit installed..
The Red graph is power/torque with stock injectors, the blue graph is stock injectors with water/methanol injection.
Quick run-down is:
Standard PD130 engine & head.
JabbaSport Cast Exhaust Manifold
Jabbasport Garrett Turbocharger
JabbaSport De-Cat Downpipe
Blueflame Cat-Back Exhaust
Jabbasport Single Mass Flywheel
Sachs Clutch Kit
Quaife Differential
Pro-Alloy Intercooler
Stage 2 Snow Performance Water/Methanol Injection (175mm Inj)
JabbaSport Custom Map
Kev
and when you tune a car for good top-end power, the crossing point of torque/bhp does go up as both peak higher up. Here's an example using my old dyno run from 2007.
(actually, this is a bad example as scaling is different but it shows how peak torque & bhp rises up the rev band at least)
PS: I've just clocked how strong the above Jabba dyno shows the car is at the very top end. Still well WELL over 200bhp as it hits the limiter.
  • 9 months later...
A quick update to this thread...
Another customer with a Stage 3 Jabba Turbo Kit..
JabbaSport Garrett Turbocharger
JabbaSport Fitting Kit (Anti-Surge, Water & Oil Lines Etc)
Milltek Cat-Back Exhaust System
Pro-Alloy Custom Front Mount Intercooler
JabbaSport Custom Remap
JabbaSport Balanced & Lightened Single Mass Flywheel
Sachs Performance Organic Clutch Kit
Auto Tech WaveTrak Limited Slip Differential
Wizards Of Nos Dry Nitrous Kit - Soon to be fitted
380lb.ft torque & 255bhp on standard injectors & nozzles. Customer has Nitrous ready to fit which is why we've dropped the torque a little on just diesel alone..
Kev
Edited by Jabbasport
hi kev,
as you know ive got nearly all of this setup apart from the new-
oh and i need a LSD+ your custom re-map
can you like do me like a deal with just these bits?
cheers
simon
Yes, standard EGR because if you remove the whole EGR/Anti-Stutter from a BLT engine it throws up a circuit fault because the stepper motor is disconnected.
This car does have the "cone in box" mod, along with a flap system in the bottom of the box which opens up the bottom of the box under high boost conditions.
Kev
Just tried looking for some details on that flap system on your website but can't find anything
Kev
Kev
WOW any build threads on this????
