no rear screen demist
hi,
i've had the octy since july and got to say i'm impressed that i've had no major issues with it, just me being a biff and shorting the window/interior light fuse when in fitted the remote locking. only thing is that my rear window heater doesn't work, i live in scotland so this is kinda essential, it doesn't demist or as i found out on monday warm th window to melt frost. the light on the switch works and the heated mirros work a treat (also descovered monday). is this a comman problem and is there an easy fix.
before its suggested i've checked all the fuse and cleaned and reseated the connections.
thanks in advance for any help
ian
Start by giving the bus elements a close eyeball either side of the connectors.
If there are no breaks there then make sure you have current at the feed side of the screen. If you don't, the break is probably at the hinge fold on the tailgate.
