Please Help!!!!!!!
hi guys, i have drove 80 miles back from work tonight. stopped the car for about 5 minutes while going into shop. Came back and started car, then pulled away and then it happedned a clunking noise and then a noise that sounded like ehaust blowing. stopped the car listedned to car while not moving sounded alright, so i gave it some juice, still nothing, then sure enough when i put it back into gear when i pulled away about 1200 rpm clunking noise and then loud noise when driving, it sounds like a hole in exhuast but there clearly isn't. maybe something to do with clutch/ gearbox, I have revo but don't think that has anything to do with it. anoyone had any problems like this.
i think that it is either gearbox or clutch problem, do you think they will check for remap, when I take it in? ir willthey not be bothered
If its a clutch or gearbox problem it might be wise to hold off the remap for now until you get to a dealer to check.
Been to dealer they had the car for 5 days looking for problem!!!!!!!! found it, engine mount bushes had come away and making it knock, all sorted under warranty and they did a mod on the driveshafts while i was there apparently some mod that has came out when you take your car in.
Deaslership was excellent, they did not have any courtesy cars but they took me to a hire car company and pid for a car for me while mine was in. Also washed waxed and valeted it inside and out top result. :cool:
